2005 XJR ABS Fault after front wheel hub replacement
Hey guys. My driver front wheel bearing was shot so I replaced the whole hub with the Moog 513327 from Rock Auto. No ABS issues beforehand, and now turning the car on I get an ABS fault and the ABS light. I did turn the car on twice in the install process to turn the wheel for better access to the bolts. I wouldn’t expect that to cause the issue though? I disconnected the battery for 5m, reconnected, and the light is still there. Ideas?
luv2fly (06-12-2023)
Johnken
11-11-2017 12:42 AM
Johnken
10-14-2017 09:39 AM
