2006 Alpine Nav Disk
Old 04-14-2010, 05:07 PM
sixpackd's Avatar
Old 04-14-2010, 05:08 PM
sixpackd's Avatar
make sure you burn on dvd-dl, using the slowest speed, setting book type to dvd-rom
Old 04-14-2010, 06:19 PM
sixpackd's Avatar
one more note: this may update the firmware on your navigation to 9.03 or 9.3 (I dont remember what the screen said).
The screen will show a progress bar to show you the progress. Once the progress bar hits about 95%, it will stall. just wait for it. it will take another 5 minutes before it is complete.
It scared me when I installed into my car, but afterwards, everything works perfectly.
Old 05-05-2010, 02:39 PM
Orchidgal's Avatar
Has anyone sucessfully downloaded and installed the update in this thread? I'm a little hesitant to install because of the firmware update - I don't want to brick my nav system. (2004 XJ8 Vanden Plas - still has original DVD dated 2002 it came with) Thanks!
Old 05-06-2010, 02:20 PM
Mhotep's Avatar
I downloaded over the weekend. Works fine for me. Now if I can figure out how to do bluetooth!
Old 05-08-2010, 10:32 PM
Orchidgal's Avatar
Thumbs up
Ok, so I downloaded and installed last night... and it worked perfectly! The firmware update took less than 5 minutes. Thanks to sixpackd for posting the links and directions!
Old 05-10-2010, 10:23 AM
Drew's Avatar
It worked great for me too! For any one around the Chicago area this has the 355 extension.
Old 05-10-2010, 04:53 PM
JAG06's Avatar
I have a 2006 XK8 with alpine navigation. Will this work on mine? I thought no updates to alpine? Hope you give me good news.
Rich
Old 05-11-2010, 02:55 PM
budsang1's Avatar
what program are you guys using to burn the files to a disc?
Old 05-12-2010, 01:02 PM
Drew's Avatar
I spoke to soon. The Jag nav wouldn't allow me to input an adress and I removed the disc to insure it was clean. Now the system keeps telling me it's not a maps disc.
Old 05-13-2010, 01:20 PM
Mhotep's Avatar
I used a macbook. Built in program I thinks it's call Disc Utility. I think on Windows a good program is Nero. Just make sure to burn at a low speed.
Old 05-13-2010, 01:23 PM
Mhotep's Avatar
Sorry to hear that. I been using mine since last week and works great. USed it yesterday to find local pizza hut. Try doing it again and burning slowly. Could it be the disc maker made a bad one?
Old 05-13-2010, 02:49 PM
Drew's Avatar
Ya, I will try. My neighbor helped my out, I don't have a DL DVD burner. He said he burned it at 2x.
Old 05-13-2010, 06:18 PM
timfountain's Avatar
I also found the reader in both my X and XJ8 seem to be very sensitive to the manufacturer of the DVD. I literally burnt through 20 or so DL DVD's before I found a combination that worked.
Nero 9 and Memorex Dual Layer DVD burnt at the lowest speed my DVD would burn (4x) worked fine when I backed up my original NAV disc....
Old 05-14-2010, 09:21 AM
Wyndance's Avatar
Default Nav Disk
2006 Aplpne Nav disk? I thought the 2005 was the last year for Alpine in XK's. And the last update was 2003 what is the part # of this 2006. Here is the last part #, I know of / Jag 4W83-10E898-GA / Alpine BM9JG91F
Old 05-14-2010, 01:07 PM
BuckMR2's Avatar
The XK uses different Nav Discs to the XJs in this XJ forum!
Old 05-16-2010, 11:12 AM
budsang1's Avatar
Do these .rar files need to be converted before burning? Sorry, i'm very computer illiterate
Old 05-16-2010, 07:31 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
A .rar file is similar to a .zip file so you will need to get something to unpack them, e.g. Winrar.
Old 05-16-2010, 08:06 PM
budsang1's Avatar
I got it, thanks, it worked great
Quick Reply: 2006 Alpine Nav Disk
