2006 Jaguar XJ8 - air suspension
Welcome to the forums aparlato,
I've moved your question from General Tech Help to X350 forum. This is the place to post technical questions about your model.
Too many things to look for, really. Do you hear the compressor actually run? Is the car actually sitting on the bump stops, all the way down? Numerous places that leaks might occur, or the struts themselves could be blown. Without a scanner to read codes and data you don't even have a hope of knowing what's going on. A scanner will show you stuff like actual height readings, reservoir pressure, and of course, the error codes stored. Without a scanner you'll be blindly throwing parts at it, possibly never the right parts.
Search this forum for 'Air Suspension' and you will have enough bed-time reading to last you a lifetime!
Perhaps start by familiarising yourself with the system by reading Don B's excellent post on this subject: Air Suspension & ECATS System Summary: Components & Operation - Jaguar Forums - Jaguar Enthusiasts Forum
Can you hear the compressor running with the ignition on? Thats a good place to start. If not, check the work you did on the compressor. If it is running, check out the front struts first. One of mine had such a bad leak she wouldnt lift at all. You can also disconnect and plug the strut air lines one at a time until you find the problem. Hope this helps.
Steve
Steve
silversurfer1221
07-01-2019 09:15 AM
FS[SouthWest]: For sale air suspension components 2006 xj8
locorebob
09-23-2017 04:22 PM
