2006 VDP causes my wife's hearing aids to click.
Old 11-25-2019 | 03:55 PM
NCJagman's Avatar
Default 2006 VDP causes my wife's hearing aids to click.
The title sums it up. Both this 2006 VDP and the 2005 VDP we had both cause clicking noises in my wife's hearing aids. Without any clever replies please as this is a serious question, has an other XJ8 owner had this problem and, if so, is there a suppressor of some sort that would stop the interference?
Old 11-25-2019 | 07:52 PM
JRT-MG's Avatar
Does it only do it when stopped, or in reverse? It could be the parking sensors, since they are ultrasonic.
Dave
Old 11-26-2019 | 12:43 AM
WLinSTL's Avatar
Yes. My wife has the same problem in my 2007 XJR. No one else can hear the noise when they are sitting in the passenger seat, but my wife hears it when her hearing aids are in her ears. If she turns her head sideways the noise goes away. I thought perhaps the electric motors for the adjustable seat or headrest were causing it and I have not found any way to get it to stop. The only solution so far is for her to remove them or turn them off.
Old 11-26-2019 | 08:16 AM
NCJagman's Avatar
Thank you. This is exactly what happens with my wife. There must be a solution other than removing the hearing aids
Old 11-26-2019 | 01:13 PM
alecescolme's Avatar
My Dad has complained of the same issue, I think it might be the occupancy sensors in the headliner.
JRT-MG (11-27-2019)
Old 11-26-2019 | 05:55 PM
djsizzle's Avatar
This seems so nuts to me. I am sorry this is happening to everyone.
Old 11-27-2019 | 12:23 PM
JRT-MG's Avatar
Good point, I forgot about the occupancy sensors.
Old 11-27-2019 | 02:45 PM
Norm NC's Avatar
Smile Hearing Aid noise
We had the same issue only worse with my 07 XJ8. A lot of checking found it is the hearing aid reacting to the occupancy sensor.
It is an issue with the frequency the hearing aids respond to. The dog cured it when he chewed the hearing aid. A new hearing aid, no more issues.
The following 2 users liked this post by Norm NC:
Partick the Cat (11-27-2019), wwr (02-10-2020)
Old 11-28-2019 | 11:53 AM
mpcook's Avatar
I have exactly the same issue in my 2005 XJ8, recently purchased. It is only a problem when I am in the passenger seat and my wife is driving (I wear the hearing aids in the family). My solution is to run to the driver's side door as fast as I can when we head out to the car :-) Would love to know if anyone has found a way around this issue as well, by blocking the signal in some way?
Old 12-04-2019 | 08:11 PM
Mark in Maine's Avatar
It's a no brainer. It's the freqs in the passenger seat occupancy sensors. They are ultrasonic. There must be a solution other than driving, or being chauffeured around town in the back seat. I'll see if other manufactures have this issue.
Old 12-05-2019 | 04:50 PM
NCJagman's Avatar
Thanks. I hope you find a solution.
Old 12-05-2019 | 08:03 PM
Sean W's Avatar
Give this a read. Apparently a work around noted in post 23 of this thread:
https://www.jaguarforums.com/forum/x...-125345/page2/
Old 12-08-2019 | 07:21 PM
NCJagman's Avatar
Here' a quote from another post.
"We initially got around the problem (clicking) by putting a wide piece of tape on the edge of the center ultrasonic sensor."
My question is, where is the center ultrasonic sensor? I've got the gaffer tape all ready to go.
Thank you.
Old 12-11-2019 | 12:27 AM
WLinSTL's Avatar
After experimenting a bit, we've found that if my wife removes one hearing aid and turns it off, the clicking stops. If she leaves the other hearing aid turned on and in her ear, she can stiff hear well enough to carry on a conversation, hear the sounds of the car, and hear the normal road noises like horns, sirens and so on, but she no longer hears the annoying clicking.
Not the best solution by any means, but it works.
Old 02-10-2020 | 08:53 AM
NCJagman's Avatar
Here is the source of the problem. I'm still looking for a solution/
https://www.eetimes.com/ultrasonic-s...ag-deployment/
Old 02-10-2020 | 11:28 AM
NCJagman's Avatar
I've done a bit of digging and came across this site which explains what Jaguar have done which causes the clicking. Jaguar refer to the system as Advanced Restraint System. Here's the link. https://www.eetimes.com/ultrasonic-s...ag-deployment/
I then searched for and found the Electrical Guide for the 2006 XJ8. http://jagrepair.com/images/Electric...al%20Guide.pdf
The **** system is covered (pun intended) on pages 169 and 170. Bear in mind that this is for a RHD car.
If we have any electrical engineers on the forum they might be able to tells us how to disable the system.
There are many, many owners and passengers with hearing aids which suffer due to this ARS system including my wife. If I cant fix it I will be forced to sell the car.
Old 02-10-2020 | 02:19 PM
ChrisMills's Avatar
Left-field response. I had random clicking noises coming "from my dashboard". Is it the keys jiggling? Nope.
Turned out to be my wife's incessant texting keystrokes just outside my peripheral vision.
The only strange thing (to me but probably not to you) was how long it took my neurons to connect. (Months!)
Old 09-14-2021 | 08:55 PM
WLinSTL's Avatar
Wife got new hearing aids and the problem went away.
rwh9056
22
03-30-2019 02:49 PM
tofercali
08-09-2012 03:54 PM
pnyklr
10-04-2010 04:41 AM
cutlass
Interior
02-09-2010 10:14 AM
11-29-2007 08:40 AM
Quick Reply: 2006 VDP causes my wife's hearing aids to click.
