2006 VDP Oil Pan Gasket Replacement
Hello all,
Please someone provide me with the tightening sequence and torque settings for the oil pan gasket bolts, and drain plug for my 2006 Van Den Plas-Naturally Aspirated 4.2L
Been searching everywhere but can't seem to locate the info.
Recently out of work and trying to save some money.
Thank you.
Thank you.
Welcome to the forum mrlbjohnson,
I've moved your question from General Tech Help to X350 forum. This is the place to post technical questions about your model.
TORQUE:
Oil pan retaining bolts: 12 Nm / 9 Lb-ft
Oil pan drain plug: 25 Nm / 18 Lb-ft
TIGHTENING SEQUENCE:
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
TORQUE:
Charles Wan
10-06-2015 09:12 PM
BStopek
03-03-2013 11:30 AM
