2006 VDP - rear speakers don't work and rear sensors don't work..
is this just a coincidence? is there a way I can check the wiring system? also I swear I noticed the consul was dim and then a few minutes later it was bright as usual... is my electrical system on it's way out? thanks, sue
Received 2,190 Likes
Rear and front speakers are common and most dont even notice until the last one goes out. Park aid is a different story. You get a long tone when in reverse for a system fault and the system is shut off. If you dont have operation and the tone is not there then perhaps that sperate speaker is out.
I hesitate to disagree with 'the Man' (Brutal), who's advice I closely listen to, but on my 2005 VDP the front and rear parking aid system seems to use the regular stereo speakers.
The warning sound comes from the corner closest to the obstacle - I though it was a pretty neat system !+
If this is true of your car, then the two problems are in fact connected. Most of my Alpine speakers had 'broken' and I did the removal/resoldering trick.
Its pretty well documented on here - Alpine used a crappy solder on the speaker cone.
Jeremy
Jeremy
i hesitate to disagree with 'the man' (brutal), who's advice i closely listen to, but on my 2005 vdp the front and rear parking aid system seems to use the regular stereo speakers.
The warning sound comes from the corner closest to the obstacle - i though it was a pretty neat system !+
if this is true of your car, then the two problems are in fact connected. Most of my alpine speakers had 'broken' and i did the removal/resoldering trick.
Its pretty well documented on here - alpine used a crappy solder on the speaker cone.
Jeremy
Jeremy
Well - I use google translate, my English is not very good… I try again!
Yes, door locks and mirrors work.have checked all fuses, no one is faulty.Cannot find door windows over fuse table.Neither in the instruction book or workshop.There is no power up to the relay.Has tried to follow the lead, but it disappears under the carpet under the center console.There are really many wires there and I would like to avoid stripping the cabin altogether. ( I hope this is better!?!?)
pab
04-09-2015 04:34 PM
orlik7
09-12-2014 07:03 PM
