2006 XJ VDP Won’t Start Help!
Old 02-16-2019 | 02:12 PM
geberhardt's Avatar
Default 2006 XJ VDP Won’t Start Help!
Car has been running fine. Wife got in car and would not start. Engine turns over but does not start. Does not even sound like its trying to start. No codes.
Old 02-16-2019 | 05:07 PM
meirion1's Avatar
Any fuel pressure?
Check schrader valve at front of fuel rail with blue plastic cap.
Old 02-18-2019 | 10:48 PM
BlackKat's Avatar
If you have fuel and spark next item should be crankshaft sensor. 40 dollars at your local auto parts store. Located at the bottom of the engine bell housing.
Old 02-19-2019 | 11:16 AM
mhamilton's Avatar
There won't be a fuel test port on the '06 and up models, you have to install a T fitting between the fuel hose and rail to install a pressure gauge. These adapters come as part of fuel pressure test kits.
AD2014 (02-27-2019)
Old 02-19-2019 | 11:25 PM
Don B's Avatar
Another possible cause is low battery voltage while cranking. If the voltage falls much below 10.5 volts while cranking, the Engine Control Module (ECM) will not trigger the ignition to fire.
Cheers,
Don
AD2014 (02-27-2019)
Old 02-20-2019 | 09:46 AM
annamiata's Avatar
Check fuse for fuel pump in trunk before any fuel pressure test. I had my Jag tow to house. It had same issue with no code and crank but no start. It was a blown fuse.
20 amp fuse at F33. Not all code reader will read fuel code.
AD2014 (02-27-2019)
meaculpa
07-15-2013 06:33 AM
Drifter8282
11-22-2011 04:06 AM
vwMike2288
07-27-2009 07:18 PM
vwMike2288
07-27-2009 06:54 PM
Quick Reply: 2006 XJ VDP Won’t Start Help!
