2006 XJ8 Reflashing ECM for TSB
Hello Jag owners! New to the Forum but needing some input on reflashing this car. I have a local repair shop that I am assisting to fix. We had a tsb(xj303-014) to reflash for cold startup for the O2 sensors. They have a passthru device and signed up for the Jag site TOPIx We felashed the ECM and TCM but came up with Identification block not programmed and constant codes for suspension module which is unhooked due to a previous owner removing the air suspension. The car will not drive past 10 mph since the reflash. Wondering if there are any Techs that have experienced this or anything similar.
Thanks in advance
Bret
Thanks in advance
Bret
Welcome to the forum Bret,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
Thanks in advance
Bret
Thanks in advance
Bret
Don B (03-28-2017)
BosXKR
06-26-2013 10:20 PM
