2006 xj8 VDP dash lights
The easy fix could be a hard reset. It's not likely but worth a try.
Remove both battery leads and touch together for a couple of minutes
then replace.
You may or may not need the radio code but you will need to reset the windows.
Have your battery load tested also
https://www.jaguarforums.com/forum/x...es-help-72973/
then replace.
Farmboy (12-29-2023)
GrewUpJaguar
07-10-2020 09:38 AM
