2006 XJ8L Bonnet Open Error
Below is the location of the hood/bonnet open switch. It will be part of the latch, but on the bottom side. You should see a connector and wiring going to it.
ItemDescription1Four button transmitter2Ultrasonic sensor3Luggage compartment key-in sensor4Luggage compartment actuator5Door actuator6Front electronic module (FEM)7Diagnostic connector8Driver door module (DDM)9Transceiver module10Instrument cluster11Anti theft alarm horn12Anti theft alarm horn (battery back-up)13Rear electronics module (REM)14Inclination sensor15Vehicle horn16Hood switch
It's on the right hand latch if your standing in front of the car simple job remove the cover between the headlights and the grille makes it easier,you will see the catch there is a small cover over the latch remove the cover and you will see the switch this is a common fault usually sends the alarm off in the middle of the night
Don B (05-27-2017)
Received 13,203 Likes
A common problem is that one of the clips on the plastic housing of the switch breaks so it won't stay in its proper position on the latch mechanism. An easy fix is to fashion a jumper wire to insert across the terminals in the harness electrical connector and fix it in place with electrician's tape (or heat shrink tubing if you have some). Secure the connector to the metal framing with a zip tie or such so it doesn't flop around. You won't get the false bonnet open alarms anymore, but you'll also have to pay attention to know when the bonnet really is open. Of course, drivers have been doing that for 100 years anyway....
Cheers,
Don
Cheers,
Don
