2006 XJ8L Foglight Replacement
I have a broken left front foglight on my 2006 XJ8L. I have purchased a replacement. The unit appears to secured by a tab and two screws. The owner's manual is of no help in instructing how to access the unit. What is the best way to access the mounting screws? Does the front air dam fascia come off, or do I have to remove fender lining and access the unit from the rear?
Yeah... the tab is on the top so just remove part 4 or 5 depending on what side your working on and there you should see the 2 screw
http://www.manhattanauto.com/cms/Man...guarParts.html
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
