2006 XJ8L transmission does not shift properly
My 2006 XJ8L when I start from stop shifts into low but will not up shift as I speed up. If I go to about 15 mph and move shift lever to neutral and back to drive it shifts ok and work ok until I stop again. Any idea what is wrong?
Thanks,
Al
Thanks,
Al
yikes! First, I would check the fluid level.
https://www.jaguarforums.com/forum/x...-video-115169/
If you can't do that yourself, take it to a dealer or 'reputable' transmission shop who has worked on ZF transmissions before. If the fluid is good, you need to have it looked at by a dealer tech...especially if there is no fault codes and CEL showing.
You may have a valve body issue, i've heard of and had one on my xk8. Comparing to a transmission rebuild, the valve body isn't a huge expense...$400-$800 parts cost, depending on your rebuilt source.
aholbro1
08-05-2021 05:02 AM
