2006 XJ8L Won't start - Pump ox sensors replaced
Old 04-27-2013 | 11:16 AM
nthimis's Avatar
Default 2006 XJ8L Won't start - Pump ox sensors replaced
OBD codes indicated fuel pump, ox sensors all changed with new. Got problem down to where if I short a relay on the rear fuse box by battery it will start and run fine. It appears something is not kicking off relay. Problem started with this being an intermittent problem and slowly progressed to not starting at all. Once it starts it runs fine.
Old 04-27-2013 | 11:17 AM
nthimis's Avatar
Also, rear fuse box replaced.
BrentGardner
28
04-26-2024 04:08 AM
fast40driver
04-19-2024 08:24 AM
1964Daimler
09-03-2015 12:41 AM
perfectphoto
08-29-2015 11:11 PM
Drew2006
08-28-2015 05:22 PM
Quick Reply: 2006 XJ8L Won't start - Pump ox sensors replaced
