2006 xjh L jaguar won't run.
I was driving my auto xj8 L and it suddenly stalled. I coasted into a safe place dumfounded. A red indicator light went on. (I had been running with an amber light and check engine message. A dealer said, when it was checked out that there were no issues and to just drive...it could be catalytic issue)Now back to my story.
I Restarted and result was I could only drive about 20 mph. I had it picked up and Jag dealer did their thing. after analysis their conclusion was ity could be catalytic or it could be something with my air ride system. So either a $4400 or $2200 fix....this without knowing what is actually knowing what the cause is.. In do not know what code they said showed up..
Opinions and educated guessing welcomed !!:
Find a new dealer. This one, who can't tell you what is wrong but can tell you what it will cost to fix, will throw parts at the vehicle until your bank account is empty.
The MIL (amber engine warning light) is set because there are DTC's (Diagnostic trouble Codes - 'error codes'). The first step in troubleshooting is to see exactly what the code(s) are. Without that, it's guesswork.
Red light - which red light?
Received 13,425 Likes
I was driving my auto xj8 L and it suddenly stalled. I coasted into a safe place dumfounded. A red indicator light went on. (I had been running with an amber light and check engine message. A dealer said, when it was checked out that there were no issues and to just drive...it could be catalytic issue) [snip]
Please find a good independent mechanic with a diagnostic system capable of reading the proprietary Jaguar diagnostic fault codes and post all the codes here exactly as they appear and we'll try to help.
Cheers,
Don
jackra_1 (03-01-2018)
