2006 XJR OBD II Codes from New iCarsoft 930
I bought an iCarsoft i930 Pro Multi System with Jaguar software installed from Amazon for $121.45 plus tax.
I read codes for all systems and got the following codes:
P0420 Catalyst System Efficiency below threshold (Bank 1)
U1900 CAN Communication bus fault passive anti theft system
U2518 Missing message from electron air temp control
U2521 Missing message from ABS
B1318 Battery Voltage Low
B1676 Battery voltage out of range
B1895 Driver/passenger door ajar output - circuit failure
B2162 Right side module invalid ident.
B2533 Right rear stop lamp - circuit failure
B2496 Anti-theft horn circuit short to ground
B1987 Pedal forward/rearward motor stalled
U0121 Lost communication with ABS control Module
U0155 Lost communication with instrument cluster control module
U2516 CAN bus off - transmit error
U1262 SCP (J1850) communication bus fault
C2302 Leveling Plausibility error
C2303 Reservoir plausibility error
C1713 Left seat heater sensor fault - short circuit to ground
C1712 left seat heater sensor fault-short circuit to Batt/Disc
C1409 Parking brake apply switch circuit out of range
First of all, how long are codes stored in the various modules? How old are these codes?
Apart from the (legally-mandated behaviour of the legally-mandated codes of the) PCM, most modules store codes forever (unless cleared using a suitable device).
Really the iCarSoft tool SHOULD warn you of that!!
So you are likely looking at random codes. If you have current problems then examine that list for clues.
Me thinks you resolve the battery issue and let the codes clear themselves before clearing them manually.
As I stated most will not self-clear.
You can safely ignore them unless you have problems.
My car's had many logged (but not in the PCM) all the years I've owned it and is fine. They're no doubt from weird things like bad batteries (it's had 2 changes at least) or from TC cutting in or whatever.
Many (most) modules keep the codes logged as historic data because otherwise many a customer would finally turn up at a repair place and the tech would have no data to look at.
On my car I haven't bothered even to clear the ancient codes as it's working. Others may prefer to clear them to have a baseline.
There again, I was stuck with the only choice of diag tool as IDS/SDD or AutoEnginuity - at the time both very expensive - and it was only some years after getting the car that I had a chance to delete such old codes. I don't know what I would have done had the iCarSoft been available when I got the car. Probably read all the codes and kept a record to see if any more came up. Probably not erased them.
From reading several posts on this in the past, it is and there is an L600 V2.0 as well, which you probably want to go with.
I changed the original Varta battery (thread in archives) about 2 years ago with an Exide L5/49X bought at Home Depot.
I checked battery voltage this morning and got 12.27 vdc. Started the car and got 14.32 vdc with the engine running.
I am thinking that the codes for battery were from when I replaced the battery. The static 12.27 seems low? for a calcium battery
jimlombardi
03-30-2023 03:34 PM
philwarner
25
06-26-2021 05:43 AM
XJR Pilot
08-10-2019 11:01 PM
jimlombardi
US Northeast
01-24-2015 06:20 PM
