2007-2009 transmission in an early 2004 XJ8
Would anyone have an idea as to what would be involved in swapping a newer 6HP26 from an S-Type/XJ into an early build 2004 VDP?
Would the valve bodies have to be swapped?
Seems like Hollander interchange breaks them up into 2003-early 2004, late 2004 to 2005, and 2007-2009. Somewhere I read that the markings on the case are different between 2004-2005 and the newer boxes.
Tired of the constant locking/unlocking of the converter when cold. Thinking of trying the Sonnax valve fix while renewing the four or five seals in between the valve body and the trans. But then I figure why not just do it right.
See here; http://kinergo.eu/news/rebuilding-of...explained.html
Don B (08-23-2016)
Thanks David. Is the sprag the same component that is referred to as a freewheel in the linked article?
I was aware of the flash and have heard that at best it minimizes the effect but does not prevent it. Strangely, my Jag dealer told me that they could not tell from my VIN whether this fix had been done.
Going back to the initial thought of swapping in a newer transmission and torque converter, it seems like there was a fundamental change involving the valve bodies:
Talkin? ?Bout My Gen-eration: ZF 6-Speed Differences in Generation 1 & 2 Valve Bodies - Sonnax
For completeness, here is the Sonnax valve overbore for the converter lockup circuit:
Oversized Bypass Clutch Control Valve Kit - 95740-13K - Sonnax
Don B (08-25-2016)
Thanks David for the additional info. I kind of figured that converter replacement was the way to do it right. Figuring it will take me an entire weekend to get the trans out (working slowly and carefully) and then another day to put it back in, plus the cost of fluid (already tried the Motorcraft SP and a new pan/filter), would it not be worthwhile to put a low mileage transmission in place of the 130 K mile example that is there now. Am close to finishing a complete suspension refresh on this car including freshening up the air shocks.
Thus my original question, how much interchangeability is there to the transmission itself? Looking at casting numbers on ebay last night it looked like 2004 through 2007 Jag 6HP26 all began with 1068. I also have some data on which separator plates were used in what year/application which I will post up soon. There is also some indication that 2004 through 2007 were all "M Shift" meaning manual(cable), I suppose at some point Jag switched to electronic shift (E-shift) on these 6HP26's whether on the 08-09 XJ or 09+ XF I don't know.
Yes, thinking of contacting ZF, they have a facility in Illinois. Not sure how open they would be as they do rebuild these 6HP26 I think - so advising on recycling yard interchangeability is not in their best interests.
Lately I've been thinking about just replacing the converter and replacing the lines which have a slight weep. A lot easier on the computing end of things - just reflash to the newer program that doesn't dither the lockup for warming up purposes as much.
There is an early and late version of the valvebody (Generation I and II per thecstc.com) but they use the same solenoids.
Nuhcgniw
08-19-2016 06:51 AM
Richie KentuckyReignman Gergely
02-14-2013 04:18 PM
