2007 XJ8 Upper Wishbone replacement
I've searched the web and Youtube for information about this model with air suspension but can't find an answer. Lots of information about earlier models.
To replace the upper wishbone do I have to remove the air shock to get access to the side bolts? If so, is the Torx bolt at the bottom of the shock a T-60?
Thanks!
Thanks!
Front or rear upper wishbone ? The lower shock bolts at the front are notorious for seizing in the shock bush. Most shops won't give quotations for the front, only estimates. If the bolt seizes, it will be necessary to remove lower wishbone and shock together in order to get the assembly on the bench to saw the bolt off.
JimC64 (09-05-2014)
Received 9,007 Likes
JAGUAR XK8 (01-27-2015)
KarimPA
09-03-2015 07:32 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
