2007 xj8L key transponder
Old 04-20-2019 | 09:07 PM
redxk8's Avatar
Default 2007 xj8L key transponder
Just bought 07 xj8L but only came with 1 key. For obvious reasons I’m looking to acquire two more key systems for back up. I understand I can buy aftermarket key with a chip and maybe have dealer program that key. although I am thinking they may not want to program aftermarket key and stick me with one of their keys for a much higher cost of course. So my question is, is this the correct key and chip code, Fo21 key and chip 4d60? Anyone know if this is correct?
Thank you, Rich
Old 04-24-2019 | 07:56 PM
mikebaker3's Avatar
I had only one fob when I bought my 2006 XJR used. You will need to take it to a dealer, buy a fob and have the computer programmed to read the original and new key fob.
Old 04-24-2019 | 09:41 PM
redxk8's Avatar
Yep, searched the net, searched tucson area for help. Spoke with a few places but seemed a little sketchy so broke down and ordered from dealer, $640.
Old 04-25-2019 | 07:57 AM
310jag's Avatar
Jesus.. How does that $640 break down?
Old 04-25-2019 | 09:33 AM
Wingrider's Avatar
Key part alone is priced @ $212.50
Plus the other half, with the transponders, or buttons, on it.
With my shop discount, it was still $170, for the key portion.
Old 04-25-2019 | 11:21 AM
310jag's Avatar
That's what I show as list, and 10% off of list, which is the normal Jag club / military / first responder discount I do. Nothing particularly special.
Even at list plus programming ($50?) there's still a lot of ground to be made up to get to $640.
Old 04-25-2019 | 08:17 PM
Wingrider's Avatar
Keep your eye on Flea bay, found a good deals on used ones.
Locksmith was selling a group, all guaranteed to work, with battery's.
But they all needed the metal key portion part, replaced first.
Old 04-26-2019 | 12:17 AM
toyman1001's Avatar
Technical Bulletin XJ501-20 may be what you are looking for.
https://www.google.com/url?sa=t&rct=...xWKZ3Be9GWUlaf
Old 04-26-2019 | 04:21 AM
paddyx350's Avatar
I bought a key from ebay including a blank metal portion, remote and transponder. Cost about 35 Euro
Got the key section cut by a locksmith for 20/30 Euro and my local indie jag guy programmed this and my existing key transponder to the car using the jag software, took him around 15 minutes and I gave him about 20 Euro. If you only have one key you have to wipe the existing one and re-program the transponder in both.
You can program the remotes yourself very easily
No need to pay a dealer those crazy prices.
Old 04-26-2019 | 08:05 AM
Wingrider's Avatar
When you have two keys programmed, that function in your ignition.
You can then program additional keys yourself.
It's as easy, & as fast, as the remotes are, to do.
Old 05-01-2019 | 01:59 AM
redxk8's Avatar
I will get the breakdown on my charges tomorrow morning. I am also first responder so I’ll ask for a discount as well.
Not sure I’m understanding the bulletin from toyman1001, do you program “each key” through all steps 1-7? Start over from step 1-7 for each key? The reason I ask is because there is a notation “ steps 4-6 erases transponders memory? Thank you. Forgot to mention, I’m in the Tucson area and as I stated earlier I can not find a locksmith to cut a 3rd key from eBay?
Old 05-01-2019 | 11:28 PM
toyman1001's Avatar
All keys present for steps 1 - 4. Step 5 applies to each fob in sequence then do steps 6 and 7.
Old 05-07-2019 | 09:16 PM
Mark in Maine's Avatar
Call the dealer. Mine has the cutting machine. If your in good with the dealer parts dept he will do it for not much $$
AntixSD
10-18-2018 10:20 PM
JagCoast
05-11-2015 08:43 PM
MR. CJ
12-28-2014 07:13 PM
SirJag
11-28-2011 06:25 AM
sirlasc
03-22-2011 11:01 AM
Quick Reply: 2007 xj8L key transponder
