2007 XJR Security alarm goes off random
Is the switch in middle about 4 inches behind latch when I bypass the airbag light is on. cannot find another switch
Yes you have the right switch. I has just two wires, the black one to earth.
The solution must be to join the two wire together, which means it is closed permamently.
It must be some form of proximity switch which senses when the hood is
properly shut.
If you are having problems maybe set it nearer to the hood ie higher or replace switch?
properly shut.
Goya (12-10-2012)
Goya I think I have got my wires crossed!
There is a hood switch under one of the latches.
There are two latches for the hood, one of them has a switch right underneath it. Look for two wires leading to it on one side.
Remove metal cover to access it.
Often people oil the latch which gets onto switch underneath.
Sorry for mix up
Sorry for mix up
Rlover
03-30-2016 10:04 PM
hen555
09-07-2015 11:13 PM
