2008 bumper conversion on 2004 xjr
I'm buying either a 545i and doing the msport kit or xjr and doing the 2008 conversion.
Has anyone done the conversion? Or know if its possible?
I'm sure the front bumper will bolt right up and is easy to find plus the bottom mesh grille and fogs.
Rear bumper seems alittle harder to find and idk if they changed the rear end at?
Side vents should be easily made to bolt on.
I'd leave the older sideskirts as the 08+ ones seem hard to find and door protectors.
This has come up a couple of times in previous discussions, if you did not have any luck when you searched, here's a link to show you how to do it.....it is quite a bit more involved than one might think:
Jaguar Forum.co.uk • View topic - My XJR retrofit project
Marque
09-14-2015 11:17 AM
metalmarty
09-11-2015 07:05 AM
