2008 jag overheats at times
My 2008 Jaguar XJ while driving after about 45 minutes the temp gauge shows it over heating. I stopped before, no leaks, plenty of coolant, fan working. If I turn on the heat on high and fan on high temp goes down to normal after about 30 seconds, or if I stop and shut car off and start it up again it shows normal, then does it again later. I changed the temp control sensor, and it helped but still does most times, but only after longer driving of about 45 minutes. I need help figuring this out. Thank you
Jaguarbabyboy
01-11-2023 09:47 AM
MrSteve4
10-17-2022 01:39 PM
Lbdltld1
09-18-2021 09:08 AM
