2008 VDP Air Suspension Suddenly Inoperative
08 vanden plas. No error codes. System just stopped working. Fuses in r box ok. Fuse in front box for compressor nothing. Power up comp mamually works fine. Air not getting into res in trunk either. Removed feed line from air blk in trunk. Plenty of air. Wat does any one suggest ???
Hi Brnries,
I'm moving your post to start your own thread.
Are there any warnings illuminated in the instrument cluster, such as Air Suspension Fault or Vehicle Too Low?
Can your scan tool read the proprietary Jaguar C (Chassis), B (Body) and U (Network) diagnostic trouble codes? If not, is there a good independent shop in your area that works on European cars and may have a high-end diagnostic scan tool such as an Autel or Launch or the Jaguar SDD dealer-level system?
If you can get the codes scanned, please post them here exactly as they appear and we'll try to help.
Cheers,
Don
Cheers,
Don
daro31
12-22-2017 05:17 AM
klfong
08-13-2013 03:39 AM
Dave S
22
03-25-2012 02:44 PM
