2008 XJR Shudder and clattering noise on WOT
I have dived into the world of fixing the vac leaks on my 2008 XJR. Turns out the hose to the Secondary air system had fallen off, as well as the Y piece that goes to the vac tank and the SC bypass, as well as the brake booster O ring. It now seems to have all of the little leaks fixed.
The issue I have now is on WOT it is very hesitant and shudders and struggles to gain any speed past 80~ but on half throttle will comfortably do more. It seems to start having issues around 3500RPM and onces it gets towards 5000 it makes a clattering noise.
Any ideas where to start looking?
I would check fuel pressure. Has the filter been changed?
Since you have an "R" it runs both fuel pumps from 3500 rpm and up. So your hitting a problem right at 3500 rpm. I suspect your running out of fuel but this is a mystery too because it should set a code for incorrect fuel pressure?
But my bet is on fuel pump.
bikerad (06-29-2020)
Your car might not have the Schrader fitting? We did find that Jaguar dropped it at some point on the 4.2L V-8.
I used a mechanical pressure gauge hooked to the fuel rail and ran the hose so I could drive around and look at the fuel pressure.
BUT I was chasing a fuel pressure regulator code so different than what problem you have.
I have replaced the fuel filter, and the old one was in need of replacement, but the issue has not been fixed. I managed to get it to return some codes, which are the random/ multiple misfire and various cyclinders (all even) so it seems limited to one side of the engine.
The one thing i have noticed, is that the commanded AFR was down at 8 at one point where as the measured was up at 14
humbug2
31
03-12-2011 12:37 PM
