2009 4.2L sensors and vacuum lines
Need help replacing small emission vacuum lines (brittle and broken)on top of XJ VandenPLas, 4.2L normal aspirated V8. Pictures attached:
line comes out of air intake, then immediately splits to 2, then appears to have two attachments, one is a T, one just a connecter. Appears to have 3 broken lines downstream, maybe all related. "check engine" light on due to emission sensor. How important are these lines? Can one just replace the lines with new vacuum tubing? If so, not sure of the proper attachment points (diagram would be useful).
Thank you,
RFG
Thank you,
RFG
ejjbee
01-24-2017 01:24 PM
