2009 xj8l fan runs while driving awhile
Radiator fan runs most of time now and the engine compartment is only 154 degrees . When engine shut off runs for another 5 minutes. Does fan have a thermal resistor incorporated with a preset ?? This fan hasn't come on in over 4 years and temp is at halfway/meaning good no over heating concern . I understand the fan is directly fused to battery - any advice as to the problem/issue ????
THanks Chuckie
I replaced rear air shock with arnott/ all is good (2007 XJ super8.
THanks Chuckie
My fans run a few minutes upon shutdown with code reader showing engine temp in the normal 190 degree range. Service advisor claims this is normal even though it never did it before. Found very small leak at the nipple of the small upper coolant reservoir hose. Will replace reservoir when I have the time, and I suspect this will also fix the fans running issue although I don't understand why.
What is the ambient temperature, coolant temp, how long has the engine been running?
