40k service - How Much?
Your dealer should give you a price, but heres some info I dug up on the internet.
Note that that its a 45,000 service.
Hope this helps.
C Interval - Performed at 15000, 45000, 60000, and 90000 miles (24000, 72000, 96000, and 144000 km)
Lubrication
Lubricate all grease points
Renew engine oil and engine oil filter
Check/top up brake fluid reservoir
Check/top up automatic transmission fluid
Check battery condition
Check/top up cooling system
Check/top up rear axle oil
Lubricate all locks and hinges (not steering lock)
Check/top up power steering reservoir
Lubricate accelerator control linkage and pedal pivot; check operation
Engine
Check for oil leaks
Fuel And Exhaust System
Check fuel system for leaks, pipes and unions for chafing and corrosion
Check exhaust system for leaks and security
Transmission, Brakes, Steering And Suspension
Check condition and security of steering unit, joints and gaiters
Inspect brake pads for wear and discs for condition
Check brake servo hoses for security and condition
Check/adjust front wheel alignment
Check visually brake hydraulic pipes and unions for cracks, chafing, leaks and corrosion.
Check/adjust front hub bearing end-float
Check tightness of propeller shaft coupling bolts
Check for oil leaks.
Wheels And Tires
Check tires for tread depth and visually for external cuts in fabric, exposure of ply or cord structure, lumps or bulges
Check that tires comply with manufacturer's specification
Check/adjust tire pressures, including spare wheel
Check tightness of road wheel fastenings
Electrical
Check/adjust operation of all washers, and top up reservoir(s)
Check function of original equipment, i.e. lamps, horns, wipers, and all warning indicators
Check wiper blades and arms; renew if necessary
Check/adjust headlamp alignment
Body
Check condition, security and operation of seats and seat belts
Check operation of all door, bonnet, and luggage compartment locks
Check operation of window controls.
General
Road/roller test and check function of all instrumentation
Report additional work required
Let us know what you get charged!
Justin
Hope this helps.
Lubrication
Engine
Check for oil leaks
Wheels And Tires
Electrical
Body
General
Justin
albert328gts (03-27-2012)
