50K Vanden Plas Maint.
Hello all, I am a new Jag owner as of 4/5, I have an 04 XJ8 Vanden Plas. I spoke to the dealer about my 50K mile service interval Does anyone know what this entails and if it is something that can be done yourself? Also noticing a little bit of hesitation while leaving from a stop when the transmission is shifting from first to second, will the 50K maint. address this when completed? Thanks for all your replies and your time. Sorry if this was ever posted before, any direction to "sticky" posts or anything else would be appreciated.
Normally the documents provided with the car when new would have included an Owner Handbook, and also a Service Book, plus others. I would have thought the Service Book would have the service schedules and what should be done at each service. You should get these from the dealer with the car. 50k is not a lot of miles for a 2004 car so it should be immaculate.
Main thing to remember is that most services specify miles and calendar intervals with the service due on a first hit basis. A lot of people forget the calendar bit and run the car too long without a service.
In your case, I would expect to see on the schedule: -
- oil and filter change
- air filter change
- possibly a brake fluid change - this is normally a 2 year interval regardless of miles, but could be 3 years.
- a lot of inspection activities especially safety items like brake pads and discs, wheels and tyres etc.
- also checks to see if the various recalls and TSBs have been actioned.
There is a specific recall at the moment on the brake pipes to the rear, due to corrosion. It is essential you check whether this includes your car's VIN.
- air filter change
Thank you, I appreciate your help. What is your take on the hesitation from the automatic trans when shifting from first to second? The car starts out strong then acts as if it is starved for either fuel or air, then after the shift it drives normally. If I gun the accelerator the hesitation is a little less noticeable. What can be done to fix this problem?
Well I will see what happens. I just bought the car Monday. I filled the tank with premium fuel as per the info on the gas cap door. This morning I didn't really notice the hesitation, maybe the car was just still cold. I will keep my eyes on it to see if it returns. Thanks for your info.
Hi AntonB
Your "hesitation" on drive-off with a cold engine is interesting. Virtually all modern auto transmissions are electronically controlled, and this includes the program easing off the engine whilst the box changes, to stop engine torque stressing the gears and brakebands. This action takes some getting used to by those of us used to the old Borg Warner 3-speeders which just changed regardless of what the engine was doing. They were, however, very robust boxes, but now we have 5 and 6 speeders in the same space as the old boxes, so the box components have to be smaller, and, how should we say it, more delicate ?
Now in your car, you have a cold engine, with the box shutting it off momentarily to change gears, so the hesitation appears worse than when the engine warms up. In my view the gearbox program is not totally correct, and is failing to account for the cold engine and low revs. Other posts here suggest Jaguar have a fix for this involving reprogamming the box controller.
2004 VDP with aprox 50k miles; I have the same symptoms. If I take off very, very gently, the 1-2 shift is barely noticable; if I take off normally there is a slight lag, (lurch?), then it takes off briskly in second. If i take off aggresively then the shift is quicker and smoother. All other shifts are smooth.
FS[SouthWest]: Parting out 1999 Vanden Plas
Brewmonkey
21
05-30-2016 12:50 AM
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
