6 speed auto transmission fluid change
#42
Fluid Change
I've done three Jaguar Trans Fluid changes, 2 ZF6 and one ZF8. If you do it "by the book" its not that hard and well worth the effort. Just make SURE you pull the fill plug BEFORE the drain plug or pan; I had one that had an ornery fill plug took me hours to remove. The following video and .PDF should help....
wolvesfan (02-06-2023)
355rockit
12-10-2020 08:50 AM
MWMan
01-21-2017 06:29 AM
