6HP to 8HP swap
6HP to 8HP swap
Hello,
I recently bought a 2003 X350 XJ8 SWB as a project car, and one of the mods I was thinking about is changing the gearbox from the 6HP 26 to a 8HP 70
I konw that X351 came with an 8HP 70 and an AJ 50 engine, so does anybody know if bell housings on the AJ 42 and AJ 50 are the same?
(I also saw that X250 3.0 D went from 6 speed to 8 speed in 2011 - so I am hopefull)
As background, I am an eDrive developement engineer and I used to work for ZF - but in their less famous eDrive division, and now I work for Magna. I have sent a question to some ex clleagues, and If i get something forom them - I will also share.
aslo, depending on the budget developement, I am also considering the 8P75HZ from a BMW 330e - with a 48V MHEV - but that's a 50/50 chance that I will go trough with it.
Thank You in advance for any help and I will start a build thread as soon as i get my ducks in a row.
The following 2 users liked this post by OBM_Wien:
Jaroslav Záruba (09-19-2024),
ShockandAWD (09-19-2024)
Hello,
I am super-curious if the fuel consumption will be significantly lower. 😲
May be I make shorter detents and fit all 8 - that would be cool, and with the way (HP is controlled - an aftermarket TCU would alow for a lot of aditional features.
As for fuel comsumption - there should be some gains.
And If I go for MHEV may be even a bit more - but addes weight would not help - but the main idea behind this aditional effort would be the torque gain.
I don't see where there's gain enough to matter unless some of those other bits are to be altered as well?
Jaroslav Záruba (09-22-2024)
Received 13,379 Likes
Hello,
I don't know if the performance gains would be worth the trouble on a normally-aspirated X350, but it is probably possible to do the swap.
There is a lot of info online about guys fitting 8HPs to high-performance cars. Here's a video I saw recently:
For the record, I have a client with a BMW M550i xDrive with the 8HP75 that is having disturbing harsh shift problems at just 80K miles, and there are online accounts of others having similar experiences with the higher-powered BMWs.
Cheers,
Don
Ah, I have seen most of the videos on this chanel. I do not expect mutch speed/acceleration gains if i go to an 8HP70 - may be just some fuel consumption
8P75HZ would give some performance without building the NA engine
The point of this whole car / build is to be a project for me to play with, have fun - it won`t be a daily or a race/drag maschine.
As for ZF 8HP product quality - oh I am very well aware that there are good and bad variants - I did work for them ...
Not as if it just rolled out of the factory door yesterday afternoon, is it?
have fun -
captainobvious1
05-14-2024 01:07 PM
