6HP26 transmission pan gaskets?
I'm about to do a second transmission fluid change on my '05 XJ8. I previously installed a metal sump pan and I need a new pan gasket. I've been searching high and low for metal & rubber or Duraprene gaskets, but to no avail. I understand that some Fords, Land Rovers, and BMWs use the same pan gaskets. If anyone can recommend where I might source just the gaskets and their part numbers, I'd really appreciate it. Thanks!
https://www.transmissionpartsdistrib...d=1&sku=95300B
Cheap enough I'd risk buying it and trying.
OTOH, I'm one of those lifelong "lucky" at saving and reusing OLD gaskets...
YMMV?
Canuck pump engineer (07-09-2024)
BL3P-7A191-AA trans pan gasket
This was posted yesterday. Bought at Ford dealer. I'd verify before purchase. Be sure to check the link below.
https://www.jaguarforums.com/forum/x...ns-pan-247591/
yachtmanbuttson
08-31-2018 10:33 AM
05S-Stype
06-25-2016 04:11 AM
