96 XJ6 4D Sedan
Probably better if you post in the forum for your car, which from the year is one of the X300 series built 1994-1997. Look in the Modern Jaguars section. This forum is for the last of the old style XJs built of aluminium and which are totally different to your car. However, Doug's advice is correct, the squealing is because after a start, the alternator is recharging the battery. This puts more load on the drive belt, and if it's loose, makes it squeal.
