98 xj8 vdp dtc p5137
I have a 98 XJ8 Vanden Plas with a check engine light the OBDII / DTC is P5137 and looks like a fuel loop open/close problem "has not yet satisfied conditions to go to closed loop.” I can not find any information on the OBD code listed, and I have cleaned both air sensors (MAF & IAT), cleaned the throttle body, and check all wiring to other sensors ( i.e. temp, oxygen sensors, knock, TPS…) any ideas?
Other information that may or may not be related; this started when I removed my ABS module for repair and drove it for a few days without the ABS installed. The check engine light came on when I put everything back together.
rominempire
28
10-08-2020 10:39 AM
Fletch44
09-28-2015 02:21 PM
