99 XJ8 ABS Traction Control Module issue
I get the typical ABS light and stabliity/traction control warning. I have a part#LNC2210AD in the car when I bought it and says rebuilt. I sent it out to BBA and they said it was unrepairable so I bought a repaired unit from them. I put the same model# unit in that I bought from BBA which was a rebuilt. The new unit shows the same faults as the other but now the odometer/speedodometer don't work and the emergency brake light stays on. I returned the unit to BBA and put my original back in. BBA said they tested return unit and it shows good?
Why would all these other faults show regardless. If all of these faults show could the return module have been ok and something else wrong with the car causing fault codes/things not working issue?? Pump# in the car is MNC5920AC.
FDR
05-23-2016 09:18 PM
