ABS fault after airing up tires?
I'm sure the two issues are unrelated, but just in case. We are going through a cold snap here in Vegas and even had hail last night. I got out of work and had a warning light for air pressure in the spare tire. I got out my cig lighter plug air compressor and filled it up since it had dropped to 25psi. Similarly the other tires were at 28 so I bumped them up to 32psi. The car was running the whole time. The second I put the car in gear, ABS fault and Cruise Not Available illuminated. It hasn't cleared either in the few times since that I've started the car. I know it's very well possible that I could have a bad ABS sensor, but it just seems like extremely odd timing. I've got the battery disconnected currently to see if I can get it to go out first before delving into it further. All I can say is regardless of the problem, big or small, I'm getting really tired of fooling with this car.
Come to think of it, I never greased the front plug gaskets to keep from water ingress when they were installed. I'll be checking all connections.
Jon89
11-02-2015 08:55 AM
fritzvis
10-14-2015 04:51 AM
JimC64
10-13-2015 07:08 PM
