ABS fault / DSC not available issues
Have you actually checked the ABS sensors attached to the wheels? They are held in with a flimsy plastic clip and fall out very easily. Takes about 1 minute to check all 4 sensors.
I had a DSC/ABS fault exactly like you describe and a loose sensor was the culprit.
If those are ok, I would get the Crank Amps on your battery checked.
javigo1971 (05-08-2016)
The purge valve for the fuel rail? If so you will find it in the 3rd picture, a small blue (in my car anyway) valve cap, and its under there.
https://www.jaguarforums.com/forum/x...ge-how-119351/
innzane
04-03-2016 08:43 PM
