ABS Module Motor Pin Fix for X350
Hi,
I have an '04 XJ8 with an ABS Fault. The WDS diagnostic directs me to the front passenger wheel with a C1234. The wheel sensor checks out OK with a volt-ohm meter so I plan to replace the hub assembly complete with new wheel sensor.
In the event that the hub and sensor replacement does not correct the problem, I could be looking at an ABS Module fault.
I have successfully performed the motor pin re-solder technique on my '01 XJR to correct its ABS Fault so I am wondering if there is a similar procedure for the ABS Logic Module used on the 2004 XJ8.
If there is a procedure for the '04 ABS Logic Module, can you direct me to it?
Thanks for your help.
Check out this TSB
http://www.jagrepair.com/images/TSB/...%20Cluster.pdf
If you have SDD you can use this to confirm each sensor. Setup a monitor for the sensor and the spin the wheel noting the wheel rotation causes pulses on the monitor
You can do the same thing without SDD but you need a CRO to monitor the sensor input
34by151
34by151
Don B (07-12-2015)
trosty
26
12-18-2022 06:40 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
