abs sensors
abs sensors
had abs light and dsc not available come up as soon as i set off, cleaned all sensors and rear reluctor rings and its still on , can anyone tell me the abs resistance value of the sensors, both the front are 535 and the rears are 509 and 504,
many thanks
2003 x350 3L petrol
many thanks
2003 x350 3L petrol
so here is the story, i have sdd 131 with mongoose pro and have used it many times for dtc codes but when i got the dreaded transmission surge i used it to reflash the transmission and ended up bricking the car and had to have new gem and ecu and so i am a bit reluctant to use it anymore although if im not reflashing anything and only using it for trouble code diagnosis i would have thought it would be safe enough
