AC blower cycling on XJ8
I have a 2007 XJ8, and when using the ac, the blower has been cycling on and off. Does not matter if on the 'auto' setting or the manual setting. The air is cold, so doesn't need a recharge. Is there a circuit breaker of some sort that could be causing the cycling? This started about 2 weeks ago, it does not seem to be getting any worse, but happens everytime I start up the ac.
Welcome to the forum jcddds,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X350 forum. This is the place to post technical questions about your model.
The blower motor control module is a known failure item on these cars. Usually they just fail and the blower stops working entirely, but a thermal cutout fault could definitely be causing your issue as well. You can replace the module, they are readily available from Jag and the aftermarket. There's also a repair documented here if you're handy with a soldering iron and can replace two large transistors https://www.jaguarforums.com/forum/x...t-sink-126502/
jcddds (09-16-2018)
Jeffrey Adams
02-26-2024 07:05 AM
Djmcmann
02-09-2021 07:11 AM
