Acc sensor blocked
Acc sensor blocked
From time to time I get this error message when it rains, maybe once or twice a year. Recently it rained and the message came up.
Problem is, now after a few minutes of driving EVERY single time, I get the message and of course am unable to set the cruise, even though it is hot, dry and sunny. I can set the cruise and it works up until the point it errors out.
Ideas?
EDIT: I'd like to add this has been going for 7 days, every day. Tried an experiment. Started the car, drove around for less than 5 minutes, then parked, left engine on for 10 minutes. No error, then began driving again and within the usual 5 minutes up pops the error. cruise control then stops working and forward alert also stops working, however park distance sensors still work. hmmmm......
Ideas?
Ideas?
Ideas?
Good luck!
The following 2 users liked this post by xjrguy:
jahummer (08-26-2011),
Jaroslav Záruba (06-16-2024)
Hi Steve,
Thanks for the response. That gives me some ideas, particularly for a period of time I drove without the tow covers on. The problem started when I replaced the covers. Perhaps the sensor recalibrated itself? I am assuming it is the rectangular box behind the driver's side cover?
Hi Steve,
Cheers,
OOPS! I missed your point......no, there is no calibration the will compensate for any finish that is possibly interfering with the radar.
Cheers,
Sorry for so long to get back to this. I did indeed verify with the cover removed, the ACC and forward alert work without failure. I spoke with Jaguar about this and they had no idea that chrome could cause this problem.
Guess I am going to be selling these nicely chromed parts. Anyone without the ACC option want to update their bumper? It looks very nice!
ragman1171 (08-22-2014)
This just serves as a fine example of what we techs ALWAYS have to be on the lookout for. Not only do we have to worry about outright failures, but also for any other possible complication to the issue, intended OR unintended. You did good, you kept an open mind and listened to suggestions. Look what it got you.......
Keep on JagIN!
Cheers,
forward alert off on 2004 xjr
I installed a toll-road sensor on the front license plate of my car. Could this cause the Forward Alert to switch off as indicated on my display panel? I never made the connection and thought I accidentally switched the Forward Alert off but couldn't find anything in the manual to help me turn it back on again. Now I am thinking it was this toll-road sensor frame I put on. Anyone know if it is causing the forward alert sensor to be off? I guess I could take it off but before I do that I wanted to know.
It wasn't the toll-road sensor...I took it off but car still randomly displays the error message and even more disturbingly, when this happens the engine shuts off within a few seconds and the car is dead...this has happened several times to me while I was driving at speeds up to 60 MPH. To get it restarted I finally figured out you have to turn ignition off, take the key OUT and then put it back in and restart. Overall, this had happened about 5-6 times in the 4 yrs we have had the car. Next time it does it, I will take it in to get looked at.
Poet
10-06-2015 09:40 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
