accessory power after key off
Today had a friend in the car trying to charge his cell, but none of the accessory plugs or cigarette lighters stayed on with the key off. Not even the one in the glove box.
Are all of these switched off by design? Is there no way to change that? I know on some cars you can change a fuse position and get the accessory plugs to stay on with the key off.
Thanks,
-Michael
Thanks,
-Michael
I don't know that you can; would be interested if there is something in one of the fuse boxes that would allow you to do that. On my '07 XJ6L I mounted a fused accessory socket in the battery compartment. Granted, you had to put your phone in the trunk to charge it, but there was no problem routing the cord into the trunk and I charged all sorts of stuff back there. Unless someone has a solution, I plan on pulling the one from the XJ6L and putting it into my X350.
The Lighters are controlled by Relay 8 and are activated on Ign 1
The Power points are controlled by Relay 3 and are activated on Ign 2
Relay 3 also supplies ignition power to the front and rear accessory connecters
So depending on what you want you may need to bypass one or both relays
A better way again is to replace the relay with a voltage controlled relay. You can pick these up cheep at an electronics shop or ebay. Set the voltage to disable the relay above 12.2 volts
12.2 is voltage where all the modules go wacky so setting it a bit higher stops you draining the battery to a point that will give you problems. You will also be able to ensure you can start the engine to charge up the battery
34by151
34by151
It was so bad I thought my speakers might be damaged and buzzing, but sound is perfect with CDs.
Ive had phones, fm transmitter, DC converter, and usb adapters plugged into the outlets and i havent noticed any radio reception decline.
BTW, credit for the fusebox modifications goes to our very own member, whiteXKR. He's the electrical guru who has designed custom modules, harnesses and instrumentation enhancementsfor the 97-2006 xk8 and xkr. He looked at the x350 electric diagrams i provided and helped find a solution. I trust his advice in this area 100%.
Using what you did on your car, I think my way to make it a little more refined would be to get a spare relay for R3, pop it open and short pins 3-5 internally, which would enable battery power to the power points all the time (might also label it on the outside as "shorting plug" or similar). Would have to do the same thing with R8 in the front fuse box if I also wanted the cigar lighters to stay on. I like the concept though, I may give that a try!
Ha, all this so my friend can charge his damn phone in my car...
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
1964Daimler
09-09-2015 11:28 AM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
