Added mesh grill to 2004 XJ8 - you like?
After reading some other inspiration from XJ owners, I decided to update my grill and lower vent with the stainless mesh look. It was a straightforward job (2hrs) and I do like the results.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/62699-added-mesh-grill-2004-xj8-you-like-th_newgrilladded2.jpg?dateline=1384468120)
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/62723-added-mesh-grill-2004-xj8-you-like-th_img_1765.jpg?dateline=1384477516)
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/62724-added-mesh-grill-2004-xj8-you-like-th_img_1767.jpg?dateline=1384477615)
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/62725-added-mesh-grill-2004-xj8-you-like-th_img_1768.jpg?dateline=1384477615)
edited:Got the upgrades from Mina Gallery. http://www.minagallery.com/
Bundle was $288 including shipping.
Last edited by Arjtpa; 11-30-2013 at 07:26 AM. Reason: corrected typo on Mina Gallery and added web link
Yes the install was easy on upper part. Just 2 bolts and remove the existing units (all plastic tabs), install new mesh and snap back the plastic wind deflectors to hold the mesh in tight. That last part was not explained in the instructions but I figured it out.
The bottom was easy as well, but as you said, I did remove all the of the existing plastic bumper fascia, then I masked off the area and sprayed black plaint to hide the bumper parts from showing. I wasn't completely happy with the screw fastening approach they include but it turned out OK.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/63997-added-mesh-grill-2004-xj8-you-like-edobernig-107535-albums-pedals-valve-stem-caps-4349-picture-04-vanden-plas-mina-mesh-grill-14284.jpg?dateline=1385477777)
Arjtpa (11-27-2013)
