Adjust Headlights & Bright Lights Independently
Is there anyway to adjust the height of the dim lights and bright lights independently?
I upgraded my stock 2004 XJ8 with aftermarket HIDs, and they look great - but they are so bright I had to set the height adjustment all the way down. Now the HIDs low beams are perfect - lots of light, not blinding oncoming traffic - but my bright lights are useless as they are pointed at the ground.
Just wondering if anyone had figured out a way to adjust them separately. I realize that the factory settings have the brights adjusted above the low beams, but apparently it isn't enough in this case.
