air con one side not working
Hi all
2004 JAGUAR XJ6 V6 SE AUTO 3.0 Petrol
I recall a post a while ago on aircon not working properly on one side.
In simple terms : drivers side when its hot outside, no 'cold' air comes through(passenger side works with cold air coming through), when its cold outside no hot air was coming through (passenger side functions normally).
Lookers have been pretty hopeless, topped up refrigerant, still doesnt fucntion properly. I do get volume of air coming out just not the correct temperature.
So in the summer the car is stuffy and hot and in the winter its like an iceberg om wheels !
Any pointers would be appreciated. No fault codes showing.
Jason
Jason
Sounds like heater core replacement is in need. Flushing usually doesn't help if it was never done in the past. When not regularly flushed coolant sits in the core pipe and sludge builds up until it finally blocks the pipe. By the time this happens a flush is rather useless. One side of the core pipe feeds the driver side and the other the passenger side. Unless there is always someone in the passenger seat you may not notice the temp difference occurring until it affects you.
jjayp (09-27-2021)
jjayp (09-27-2021)
2008xk
08-19-2021 10:54 AM
Francesca
101
06-14-2015 07:23 PM
