Air Conditioning not working
Did this solve the problem? I have the same problem. The blower does not work for AC or Heat in Auto or Manual mode. I checked all of the fuses, and they are working.
Is there a way to test if it is the relay before ordering the part? I'd like to verify that it is this part (C2C39577) before ordering a $200 part.
Mark
Mark
BEEN THERE, DONE THAT!
Here is how to test it and how to change it:
https://www.jaguarforums.com/forum/x...er-quit-62390/
This is what it looks like:
ac problem
HI all , need your help please , my jag 2004 xj8 , the air condition system , sometimes its cold like i live in Alaska , and sometimes its giving hot air , by it self , it has nothing to do with if the car is running at idle , or driving , some times at the starts of the day its cold and then all of the sudden it goes hot , and some times its the opposite way , its hot then i leave it on then its start to cool again ???? i notes that some times of i accelerate suddenly its goes off if it was on ( cooling )>?? any idea ??
Jaguar recommend that you run the CC with the air conditioning on all the time.
The system therefore cools the incoming air and then heats it if you are calling for heat.
I think the advantage is that misting inside the car is reduced because as you know air
conditioning dries the air.
Do you run the CC this way ?
If you do then I can imagine these symptoms being produced by a faulty blend door (there are 7!)
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
