Air Conditioning Working-ish?
When i bought a nice 05 VDP a year ago I imediately ordered conversion springs, not wanting to deal with the air suspension problems and the cost. paid less then $500 on Ebay. replaced all the wheel bearings also as that was another problem i didn't want to deal with. Everything works fine and relatively small cost. These are DIY if you have tools and ability. Plenty of help on the net. The ride height is a little higher than I like but the car now clears curbs when parking. Not keeping the car forever.
I'm not keeping them forever either.
But who lives long enough to wear them out????????????????
Hell i'm 69 years old, & keep up on things.
Oil spraying the steel underneath, to slow down any further corrosion.
Doing just these few things, the cars should last as long as we do.
All the cars we have ever had, were rusting too bad to be safe, or wrecked.
Far from being worn out, as far as the drive train goes.
Never needed to check the oil level, after the first car or two.
One learns fast, or gets burned a lot learning slow.
UPDATE:
I had a garage near me inject some UV dye into my system. I have a small leak at the Compressor O-Rings. He vacuumed the system and then tried to undo the bolt to replace the O-Ring, but it was well rusted in and we were concerned that it would sheer off and leave its thread in the compressor if we used any more force! He recharged the system, but obviously I will slowly lose the pressure over the next few weeks.
I am unable to buy stop leak unless I import it from the States or the UK (as usual)….
Since my Aircon is still working (to a reasonable level) I am going to try some stop leak (I am back in the UK for three weeks next month) and if that does not work, then I guess the compressor will have to come out in order to put some heat (or something) onto this recalcitrant bolt?
Any suggestions/opinions anyone , please?
Don B (05-06-2019)
Received 13,425 Likes
Liquid Wrench and PB Blaster are commonly-available penetrants that work well. Tapping the head of the screw is worthwhile as Wingrider mentioned.
You may be able to carefully get some heat on the head of the screw with a soldering gun or small butane torch. R134a refrigerant is virtually non-flammable, but PAG oil may be flammable, so use caution.
Cheers,
Don
Cheers,
Don
EsRay (05-07-2019)
#30
#31
I have Kroil too, but I don't find that it works any better than, or even as well as plain old Liquid Wrench. It's a lot more expensive, too, so even though Kano Labs is based not far from where I live, I rarely use Kroil.
If you need to squirt parts from a distance, PB Blaster is handy for that.
In my experience it's very rare that a combination of Liquid Wrench or PB Blaster with heat or mechanical shock won't loosen a fastener.
Cheers,
Don
Cheers,
Don
#32
Agreed, about the combination approach, penetrating oil,shock, & heat, working most of the time.
Thats where the various types of pullers can really make a things happen.
This is not a puller type of job though, so use what ever you have to soak threads.
#33
Thank you to all who posted the excellent suggestions above.
Now I know that it (probably) can be done in-situ, I shall try these suggestions IF (or perhaps more likely, when) some Leak-Stop fails to provide an ongoing solution.
I realise that I will likely have to replace the O-Rings sometime, either in situ (hopefully) or after removing the compressor - I am just clinging to the stop-leak straw for the moment!
Pristine97XK8Convertible
10-16-2016 12:54 PM
04Xjrsteve
17
05-03-2015 10:31 PM
Joe Richelieu
05-04-2014 05:44 PM
