Air Filter Changing and MAF sensor
I found a thread on the cabin filter and think I am okay on that one for replacement. I couldn't find anything in the owners manual for it and I can't find anything on the engine air filter. When changing out the engine air filter do I need to disconnect the MAF sensor prior to opening up and removing the air filter. Any tricks I should know?
Thank you in advance,
Bill
Bill
Just looking at pictures of an N/A engine, it would be easier to remove the air filter if you removed the MAF sensor and the tube from the air box to the throttle body. After the tube is removed it makes it easier to access the filter. At least that's how I do it on my S-Type.
Good luck,
Mike
Good luck,
Mike
majbill (09-04-2011)
Thanks, Guys, the reason I asked about the MAF sensor on my 04 comes from my previoius Jag an 02 VDP. I didn't remove the MAF sensor on it first and got a code to show up triggered by removing the air filter and not first removing disconnecting the MAF sensor. I could not find anything in my owners
manual which made me think probably the same thing would happen if I remove the air cleaner first on my 94 without disconnecting the MAF sensor.
I'm going to order both filters through Coventry West I think.
Bill
Bill
KarimPA
09-03-2015 08:32 PM
