Air Intake hose
So for some time now the nipple on the resonator portion on my air intake pipe has been broken off. The I had always intended on replacing it and did so today. But instead of using the direct replacement part I used one for a 2006 XJ8 ( AIR TUBE for 2006 Jaguar XJ8|XR849472 ), that does not have the resonator. Besides looking cleaner its less than half the cost of the direct replacement.
![Name: 44D1700C-6029-45E4-8096-E125C7C27DDC_zpsasjdufe0.jpg
Size: 1.20 MB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/154526d1501209534-air-intake-hose-44d1700c-6029-45e4-8096-e125c7c27ddc_zpsasjdufe0.jpg)
![](http://img.photobucket.com/albums/v620/DBattles/XJ8/9B795E95-2FB9-4287-BE62-8D7D600018F5_zps94udjk6w.jpg)
I've seen them used to get rid of an intake noise or resonance for NVH issues, which is why I wondered if the original poster noticed any changes.
Besides better sight of hose clamp-area condition, and one fewer plastic band-aid to break, shedding the resonator should make periodic air-filter access one notch less tedious.
Thank you, Don. New one is now on my 'round tuit' list, and I can refrain from surgery on the original so as to easily reverse the experiment if it dasn't suit my 2005 Normally Aspirated.
Don B (09-16-2015)
Update: Actually, it seems the foto displayed automagically cycles between the two versions..
Cheap enough value-add that I am willing to risk it, even though 2005's are NOT on the cross-ref list...
xjrjag
09-27-2015 01:53 AM
