Air pressure warning antenna plug missing
2006 Jaguar XJ8 L air pressure system light is on and will NOT go off. system was working fine, until i had a tire sensor replaced and then the system went nuts. The message center is clear but the Light is on. I found the right front antenna wire has been cut and both the antenna and the plug are missing..... were can i find a replacement plug??
JimC64
03-02-2015 08:07 PM
