Air Ride
I did not do that to any i have replaced. The car will set lower in front, at least mine did, till the driver door was opened, as left side will drop when right side is raised, as well as other way around. When i opened the door to get in, the car hissed, then raised the front end, causing the compressor to engage & refill the storage tank, for next time that air is required.You will need to reset your toe in settings, then look out back, any Jaguar i changed front tie rod ends, rears replacements were needed, as well as the drop links.This too will change your alignment settings. A four wheel alignment will be needed to be done, by you or about $80+ tax at a tire shop, or garage that does them, when you are all finished.
FS[SouthEast]: 2004 XJ8 - reluctantly selling
harvest14
11-10-2016 10:27 AM
abonano
10-03-2016 10:09 AM
