air ride xj8 2004 vp suspension fault
Guest
Posts: n/a
Two error messages on display.... cats fault and air suspension fault. Replaced the front left strut that was obviously not working with a good used part and this resolved the cats fault problem. Car is up and compressor is well and performance is good however the air susp. fault remains. Took vehicle to Jaguar Dealership in Columbia, SC and the diagnosis is (2) bad headlamps and the trouble code was p1471. They claim the lamps at start-up should point down and then rise and level with the vehicle. I was advised to disconnect the lamps and the battery then just reconnect the battery and start to see if the air susp fault dissappeared....It did not and remained on along with the obviouis headlamp turn signal fault.
Really could use some trouble shooting help prior to the purchase of two new lamps....I'm not convinced dealer is correct. If he is no problem I'll replace them, however if he's wrong its an expensive diagnostic tool.
02jagstype
09-04-2015 08:20 PM
